smoke alarm
I need help on how to create a program on how to make a smoke alarm detect there is fire and show it on labview and use that signal to trigger another signal to put up the fire. I already create a program on detect the fire and show on labview but i dont no how to use that signal to triger another. Thanks for the help
Message 1 of 22
(4,309 Views)
How are you detecting the alarm? What hardware are you using with this application?
Certified LabVIEW Architect
Message 2 of 22
(4,308 Views)
I use the smoke alarm model EI100b. I use the buzzer output to sent signal to the labview. Is there away to do so?
Message 3 of 22
(4,303 Views)
How is this signal getting to LabVIEW? What hardware are you using?
Message 4 of 22
(4,300 Views)
I use the output of the buzzer when it detect smoke the buzzer will have an output voltage. That voltage to send signal. Im using NI Elvis2+
Message 5 of 22
(4,292 Views)
Ok. Depending on what you need to run the other device, the NI Elvis board has (I beleive) an analog output port as well as some Digital outputs.  Depending on what voltage is needed to run the other device you might need to create an Op Amp circuit to increase the voltage as needed.  Since its an NI elvis board, creating that circuit shouldnt be a problem 🙂
Message 6 of 22
(4,260 Views)
Original message thread
How do I connect a smoke alarm to LabVIEW
Message 7 of 22
(4,255 Views)
Thanks RavensFan
Message 8 of 22
(4,253 Views)
I want to send signal to turn on a relay. So is it possible? and do i still need to create the op amp? Thanks in advance
Message 9 of 22
(4,212 Views)
Anything is possible, you need the hardware to do it.  You can use an opamp circuit, or you can buy an NI relay card.
Message 10 of 22
(4,197 Views)
