smoke alarm
Or any relay for that matter.
Certified LabVIEW Architect
Message 11 of 22
(1,421 Views)
I have created a program but is the signal does not send to turn on the relay. How do i make it send signal to the relay. The send signal name as 'asd'.
Message 12 of 22
(1,399 Views)
If you use a DMM and when you send  a signal, what voltage do you measure?
Message 13 of 22
(1,395 Views)
Like I asked before, you need something to drive the relay.
Message 14 of 22
(1,393 Views)
I record the voltage of 1v. Is it very low. If it does, how do i increase the voltage? Thanks in advance.
Message 15 of 22
(1,391 Views)
You will need an opamp circuit to increase the voltage since you are using the NIELvis board.
Message 16 of 22
(1,389 Views)
Ok, i will try it. But how do i create a opamp, is there an example? Thanks once again
Message 17 of 22
(1,387 Views)
http://en.wikipedia.org/wiki/Operational_amplifier
Message 18 of 22
(1,380 Views)
once you have received 1vdc on your AI, then DO to a driver that is connected to your relay and external  source...that should work
Message 19 of 22
(1,377 Views)
Ive created a program smoke alarm that able to receive signal from the smoke alarm and use that signal to send to the relay. But the thing is that the sending signal is forever on eventhough the receiving no longer receive. By the way im using NI Elvis2. How to solve this? thx in advance
Message 20 of 22
(1,350 Views)
