snap image through Vision acquisition express, got a totally green image
When I use Vision acquisition express to acquire a single image, it will show a totally green image. However, if I use "acquire continuous image", it will show normally. Please see the attachment what does the "totally green image" mean!
Message 1 of 27
(4,498 Views)
try to test this by max and
also do some thing else when you grab a single image try to do it several time continuously if the second or third image become clear it is problem on your cameras ccd electrical shutter to start
Message 2 of 27
(4,468 Views)
well, it seems that still doesn't work. I also tried to snap continuously, but the second or third was still the green image.
Message 3 of 27
(4,458 Views)
sorry, i uploaded the wrong snapshot in the last reply. this one is right
Message 4 of 27
(4,456 Views)
It looks like your video mode and pixel format are not correct. BGRA is a 32-bit value which has RGB and alpha. YUY2 uses 16-bit values and I'm not sure that it has alpha. Try playing with those, or post screenshots showing all the available video mode and pixel format choices.
Message 5 of 27
(4,400 Views)
video modes have only YUY2, and the pixel format has only BGRA 8 PACKED as well
Message 6 of 27
(4,376 Views)
its still doesnt work..
Message 7 of 27
(4,349 Views)
What about the output image type?
Message 8 of 27
(4,334 Views)
it is the .PNG - RGB (32-bits)
Message 9 of 27
(4,330 Views)
What are the choices though?
Message 10 of 27
(4,327 Views)
