snap image through Vision acquisition express, got a totally green image
sorry, i dont really understand what you mean
Message 11 of 27
(1,978 Views)
I just want to know all the options in this area. Does it work fine with the manufacturer's software?
Message 12 of 27
(1,971 Views)
yes, all of them work fine except when i clicked "snap" it showed the green image.
Message 13 of 27
(1,966 Views)
What are the choices for Output Image Type?
Message 14 of 27
(1,958 Views)
there are Grayscale(U8, I16, U16) RGB(U32, U64). However, I tried all of them only RGB(U32) worked, the rest of them showed error(No decoder available for selected pixel format)
Message 15 of 27
(1,953 Views)
there are Grayscale(U8, I16, U16) RGB(U32, U64). However, I tried all of them only RGB(U32) worked, the rest of them showed error (No decoder available for selected pixel format)
Message 16 of 27
(1,947 Views)
Are you sure the hardware is designed to take still images? When I look at the product page it only mentions video.
Message 17 of 27
(1,943 Views)
let me check!
Message 18 of 27
(1,936 Views)
well, i checked the product information of my webcam, which should be capturing still images. however, i also found some reviews from other users that some users have the same problem that the webcam cannot capture still images.
is that going to work if i re-instal the Labview(Vision acquisition software)?
Message 19 of 27
(1,924 Views)
I don't know why a re-install would be necessary. Your best bet may be to work around by taking a single frame out of a (short) video.
Message 20 of 27
(1,920 Views)
