solution for our query
@thakurshubh wrote:
hello sir , please refer to this attachment n provide us a logical solution for  this..thanku
Based on the pic of the front panel it looks like they're using a serial port.  I also see a serial port terminal application in the background.  If both apps are trying to access the same port there will be a conflict.  Try closing the terminal app and run your VI again...
And please write your questions to us in ADULT english language with proper grammar and punctuation.  This is not Twitter and we are not kids.  If you can't take the time to write your question clearly, don't expect us to take the time to answer them. Smiley Wink
EDIT:  Thanks nataftsw.  I forgot to mention that the post title is important and should define your problem.  That way when others in the future search for similar problems they can find them.   PLLSSSS  HLLLLPP MEEEEEE!!! is NOT a good title.  ERROR #1 in Serial Application is a good title.
Message 11 of 11
(899 Views)
