sort data
I am attempting to make the case structure dynamic (or if there is another method), whereby if the entries in the first column change, that I can get the correct array output.  In the attached VI, the case structure is hardcoded with the first column data.
In essence, I am trying to sort the array based on the entries in the first column.   Is there a dynamic solution for this?
hiNi.
Message 1 of 8
(4,693 Views)
Turn each row of the 2d array into a cluster, resulting in a 1d array of clusters. Sort this array using the 1d sort node, then turn result back into a 2d array. Use loop parallelization when converting to/from cluster.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 8
(4,689 Views)
Mike...
Something like this...
Message 3 of 8
(4,678 Views)
Yes, and if all the OP will ever need is sort by the first column it could get even simpler. Auto index the 2d array to get rows, use the array to cluster to convert it into a cluster. The 1d sort node, sorts the array by items in the cluster. Item 0 is the first sort term, item 1 the second and so on.
Mike...
LabVIEW Champion
Message 4 of 8
(4,660 Views)
Hello Mike,
I am trying to implent your last solution but I am not getting the right output.  The "Array" does not match the "Current Array",i.e. Item 0 should be 136, item 1 should be 174 and so on...The "Array" is not the same as "Current Array"sort array.PNG
hiNi.
Message 5 of 8
(4,640 Views)
You're trying to hard. This is what I meant:
Like the note says, the conversion to the cluster defaults to 9 elements. So you may need to reset that. The conversion from cluster to array, doesn't care how may items are in the cluster.
Mike...
PS: If yiou want the first row to be handled differently, strip it off before you do this...
LabVIEW Champion
Message 6 of 8
(4,631 Views)
Hello Mike,
If I change the index on the "Current Array", you can see that the array is indexed correctly...Index 0 starts with 136, index 1 starts with 174 and so on...with your solutions, "Array" does not change till I index the array to 39, i.e. index 39 = start 174.
I am trying to get the data in a format such that I can select the relevant index and get the corresponding number...i.e. index 0 = 136, index 1 = 174 and so on.  I would like to use this array (just like "Current Array") for data manulipation later on.  Your solution is not allowing me to index the array correctly.
hiNi.
Message 7 of 8
(4,623 Views)
Accepted by topic author hiNI
Maybe with a little help from Variant Attributes...
Message 8 of 8
(4,592 Views)
