sort timestamp array
And for programming and background its YYYY/MM/DD but when displaying this to user we generally convert it to DD-MM-YYYY
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 11 of 21
(2,705 Views)
Number should always be written in a MSB order, regardless och which numbers it is, thus it should be YYYY/MM/DD HH:mm. Other solutions are actually misleading and stupid. How often do you hear people talking about how they're 5"6' or the time is 48:8 (although you usually say 17 past 5, but that usually refers to the hour being relatively well known, just like some people answer 81 when asked how tall they are, since the 1m is rather obvious).
Powerlifters have the same use of language, they lift/train at 60kg, since the 100 is redundant. 🙂 Technically it'd be '60 kg then, since it's an abbreviation.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 12 of 21
(2,690 Views)
Dates should probably not be written in a culturally ambivalent fashion. Year first is not common in any cultural context I've encountered, and obviously whether you put the month or date first depends on where you are. However, as a basic timestamp, without punctuation (eg 20131026), an 8-digit year-month-date sorts correctly.
_____________
Creator of the BundleMagic plugin for LabVIEW!
Message 13 of 21
(2,686 Views)
Welcome to Europe/Sweden. Date's are always written as 131026. 🙂
/Y
Qestit Systems
Message 14 of 21
(2,683 Views)
You have full control over the timestamp indicator format and sorting of timestamps is always correct.
As long as you don't try to sort ASCII formatted time strings (but that would be asking for trouble anyway!), you are always fine.
Message 15 of 21
(2,679 Views)
ASCII formatted is axactly what I was referring to. If you must produce an ascii formatted timestamp, there's only one way I can think of to format it that will sort correctly.
As for how Sweden does it, the Göteborgs-Posten uses 26 oktober 2013. Sydsvenskan does it the same way. Which is pretty much what I expected from living in Europe. Like I said, year first is uncommon in daily life, though useful in a programming context. I think programmers need ot be aware of how dates are read and format accordingly.
_____________
Message 16 of 21
(2,675 Views)
And that is one I've never heard at all because I've never heard heights referred to in "meters".
Message 17 of 21
(2,663 Views)
@Ranjeet_Singh wrote:
Unused elements says MM-DD-YYYY(I Saw that). As it was told earlier that this is perfecly valid but we normally follow DD-MM-YYYY. Just I uploaded the VI with same format.
It depends on who "we" are.  In the USA, it is common to use MM/DD/YYYY.  If you are a programmer, you probably use YYYY/MM/DD.
No We here needs to follow DD-MM-YYYY becasuse here we are comfortable with that format only.
No disrespect intended, believe me - but that is an incredibly conceited thing to say.  There are several "standard formats" depending on where you are and what you are doing.  You definteily don't speak for all of us.
Bill
CLD
(Mid-Level minion.)
Message 18 of 21
(2,642 Views)
1.68m tall here, or '68. 🙂
/Y
Qestit Systems
Message 19 of 21
(2,634 Views)
True, they do. But if writing dates compact, as in bithdates or social security numbers, it's in the 131026-form.
/Y
Qestit Systems
Message 20 of 21
(2,632 Views)
