sort timestamp array
billko wrote:
No disrespect intended, believe me - but that is an incredibly conceited thing to say.  There are several "standard formats" depending on where you are and what you are doing.  You definteily don't speak for all of us.
Yup pretty much.
If your users are are technitions who understand MM/DD/YYYY then that's likely what you should show your users.  Code for your audience, while also attempting to not dumb it down for them.  Of course if the user never sees it, it doesn't matter as long as it meets your requirements, and meets your needs.
However if you are looking to get a string from a timestamp, you are welcome ot use the ISO standard, you can do this quite easily in LabVIEW.
http://lavag.org/topic/15034-timestamp-support-for-format-into-string-scan-variant-from-string-strin...
Message 21 of 21
(785 Views)
