sound card microphone input level control
Hi community:
I need control the sound card microphone input level from LabVIEW. With lvsound2.dll i know that is possible control the output level but not the microphone or line input. Please help me.
(3,537 Views)
Dear peter.go good afternoon,
I hope that you are doing great, can you please help me to understand what exactly do you want to control about the input?, because if it is related to the conditioning of the signal you can use our modules to acquire for example a voltage signal and define the input range and the signal is automatically conditioned, this is one of the advantages of our cards.
If you are just looking to select the input device (control the # of channels (mono or stereo), Resolution, duration and sample rate), you can use the Express VI Acquire Sound and there are some examples in Help > Find Examples > Search > Continuous Sound Input. This way you can use the adapters in your computer. You can find the Express VI at the block diagram pallete > Graphics and Sound > Sounds > Input > Acquire.
Thank you for contacting the forum support,
Best Regards,
CaEnOs
(3,447 Views)
Thank you for your response. I need control the input volume control or level control of the microphone or line input of the sound card.
The problems is resolve, I find an activeX control WaveExCtrl.dll that take the control of the volume of this input.
Thank for all.
(3,421 Views)
Hi Peter,
Is it possible for you to send me the WaveExCtrl.dll? I've been searching on line and on my computer trying to find/get such an activeX control but haven't had any luck. I would like to be able to control the mic input volume/level programmatically in my test program that I'm working on. So your help would be greatly appreciated.
Thanks very much!
Spring
(3,216 Views)
