spirometer with differentiel pressure
hi,could you help me /
i want to realize a simulation in labview of spirometer with defferentiel pressure and i want to plot volume in time and extract  lungs volumes(tidal volume, IRV,ERV) and respiratory rate and minute volume and maximal flow.
file:
https://drive.google.com/drive/folders/1lsbLUhtt07tHzcVNUzsaPr3ZbRWlr3Df?usp=share_link
Message 1 of 10
(3,638 Views)
with differentiel pressure sensor
Message 2 of 10
(3,635 Views)
Accepted by topic author maroua23
Hi maroua,
please attach your files directly to your message instead of using 3rd party hosting services!
What is your problem?
Are there any errors?
(Btw. it would help to downconvert your VI to LV2019 to read a broader audience: File->Save for previous.)
Message 3 of 10
(3,609 Views)
when i want to attach a file to a message,it appears an error that's why i use URL.
Message 4 of 10
(3,587 Views)
Hi maroua,
which error appears? Can't you even attach a ZIP file containing your files?
Message 5 of 10
(3,566 Views)
Hi.
it's impossible to share a zip file .
it's the same file that I shared already.for me i want to plot volume in graph like this photo and find this all volume except residual volume.
Message 6 of 10
(3,557 Views)
Hi maroua,
Then you need to collect all the measurement data.
After you done this part of the program you can start the data analysis, by implementing your own analysis algorithm…
Message 7 of 10
(3,512 Views)
hi,
how can i collect he measurement data
Message 8 of 10
(3,484 Views)
Hi maroua,
Collect the samples in a shift register (using a BuildArray node).
This is very basic LabVIEW stuff: did you notice those Training Resources offered at the top of the LabVIEW board?
Message 9 of 10
(3,463 Views)
hi,
I didn't notice.
thank you i will try.
Message 10 of 10
(3,400 Views)
