Peak counting using spirometer sensor
Hello All,
I am trying to write a code where is able to read the signal of a spirometer and count the number of peaks in a certain time interval. So far, this is what I have done but I still struggling with that.
Thanks in advance!
(4,185 Views)
Please down convert to LV 2015 and share.
Not able to VIEW Code
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(4,153 Views)
Accepted by topic author castrol124
There is a sample VI in the NI Example Finder called "Peak Detection and Display" that shows how to incorporate the Peak Detector.vi within LabVIEW with a while loop to count the number of peaks during a given cycle.
(4,126 Views)
Thanks for your response!  I already achieve this!
(4,113 Views)
Hi please if you have already worked on a spirometer project can you send it to me. because i have an cademic project about it,
(1,791 Views)
