unable to read QR code with labview
Kindly ask for your assistance.
Trying unsuccessfully to decode a QR code through labview.
I'm able to read the code through online QR scanners (such as: https://www.online-qr-scanner.com/) or with some python codes but not with LabVIEW.
I'm attaching a small VI and an example image.
using LV2018 32bit. have vision module installed.
Anyone know what's the issue?
thank you in advance.
Message 1 of 8
(2,639 Views)
No Attachments/Missing Attachments.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 2 of 8
(2,636 Views)
soory, added now.
Message 3 of 8
(2,605 Views)
any idea?
Message 4 of 8
(2,557 Views)
Check the below link, it supports for Multiple QR Code but you can modify for reading single QR code
How Do I Read Multiple QR Codes Using NI-Vision? - NI
Message 5 of 8
(2,548 Views)
Thanks, tested it and still nothing, cant read the QR image 😕
Message 6 of 8
(2,528 Views)
I dont have VAS installed to check the reason for the failure, You can move this post to Vision Board.
https://forums.ni.com/t5/Machine-Vision/bd-p/200
Message 7 of 8
(2,483 Views)
will try there, thank you
Message 8 of 8
(2,449 Views)
