split number data string
I have an input data, let's say
"012345678"
How can I split it into 3 digits data form as
"012" '345" "678" ?
Message 1 of 15
(9,399 Views)
Here is a basic loop which will do what you want.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 15
(9,394 Views)
As your suggestion only has 1 output, but I need it to be separated into 3 outputs.
It's actually a blood pressure reading as the 1st 3 digits for systolic pressure, 4th-6th digits for the diastolic pressure and the last 3 digits for the mean blood pressure. I need it splited into 3 data and displayed.
Thank you very much!
Message 3 of 15
(9,387 Views)
The output is an array and all three values are there. The first three characters are stored in array[0], the second three characters are in array[1], and so on. This is doing what you need. After the loop has run simply access the individual array elements and display/process them as needed.
The array is a generally approach whihc will work with any length string.
Mark Yedinak
LabVIEW Champion
Message 4 of 15
(9,380 Views)
Accepted by topic author chuah
Seems like you have a fixed format so you could do this.
Message 5 of 15
(9,376 Views)
Thank you!
Message 6 of 15
(9,352 Views)
Could I ask what the center function is, that seperates the number? I need to do something similar - split a 4 digit number into 4 digits.
Message 7 of 15
(9,148 Views)
That would be the Scan From String function.  It is found in the String pallet.
Message 8 of 15
(9,136 Views)
Deleted
Message 9 of 15
(9,128 Views)
Wire the outputs to indicator terminals.  The terminals correspond to indicators on your front panel.  You might want to check out some tutorials such as LabVIEW 101.
Message 10 of 15
(9,125 Views)
