split number data string
Hello Darin.K,
I have similar problem can plz solve it
INPUT = 25.656;25.659;25.669;25.679;25.684................
I have input like this then how u will devide this numbers and save it in array
I know to save in array but I don't know how to split the values
looking forward for your support
regards,
vinay
Message 11 of 15
(1,699 Views)
Use Spreadsheet string to array function with ; as delimiter.
then you will get the values as
25.656
25.659
25.669
25.679
25.684
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 12 of 15
(1,692 Views)
hello palaniveIT,
thank u I got it but one more problem I identified while running the program is
as u can see in attached pictures there is data in two line and I can successfully transferd to the array but I observed in graph that
there is a two line in graph I need single graph value with whole data how can I do it
regards,
Vinay
Message 13 of 15
(1,681 Views)
hello palaniveIT,
regards,
Vinay
Message 14 of 15
(1,681 Views)
Hi Vinay,
you have two lines with 5 values each.
You convert this text into a 2D array with 2 rows and 5 columns.
You display that 2D array in your graph, which uses one plot per row.
What else do you expect?
What do you want?
When you only need one plot of all 10 values you need to reshape the array. (Or append the rows to get a 1D array…)
Message 15 of 15
(1,678 Views)
