splitting a string
I apologize for posting yet another trivial question about splitting strings. I read through many suggestions for this, and didn't see
a general answer.
String: asd_dw_22_Lx-2.gm
How do I split this into asd, dw, 22, Lx-2.gm (clearly the desired string components are those elements separated by "_").
The output should not be a specific component, but any number of components. I imagine a VI that takes the above string
as input, and knows the delimeter is an underscore, and outputs asd, 22, Lx-2.gm.
Now, what if the separator is a dot, a tab, a space, etc. Is there a VI that takes an input string, a separator (defined by the user),
and spits out anything it finds between the defined separators?
(3,589 Views)
Accepted by murchak
Yes. Spreadsheet String to Array.
(3,587 Views)
Thanks!
How do I wire a constant string array to the array type.
When I right-click and create a constant, it is of type 2D double. I can easily change
it to 1D, but how do I change that to a string type?
(3,580 Views)
Got it!
Thank you very much
(3,572 Views)
