splitting a string
I apologize for posting yet another trivial question about splitting strings. I read through many suggestions for this, and didn't see
a general answer.
String: asd_dw_22_Lx-2.gm
How do I split this into asd, dw, 22, Lx-2.gm (clearly the desired string components are those elements separated by "_").
The output should not be a specific component, but any number of components. I imagine a VI that takes the above string
as input, and knows the delimeter is an underscore, and outputs asd, 22, Lx-2.gm.
Now, what if the separator is a dot, a tab, a space, etc. Is there a VI that takes an input string, a separator (defined by the user),
and spits out anything it finds between the defined separators?
(3,571 Views)
Accepted by topic author murchak
Yes. Spreadsheet String to Array.
(3,569 Views)
Thanks!
How do I wire a constant string array to the array type.
When I right-click and create a constant, it is of type 2D double. I can easily change
it to 1D, but how do I change that to a string type?
(3,562 Views)
Got it!
Thank you very much
(3,554 Views)
