spread sheet file to the formula loop
I have a spectrum data wavelength vs intensity ranging from 600-800 nm, now i have to convert wavelength (x-axis) to wavenumber - i should get a wave number vs intensity output. I did the following code, But I see only first value is converted to wavenumber. Can anyone give me some suggestions to improve code.
Message 1 of 22
(2,599 Views)
Hi KK,
Use the AutoCleanup button to improve your code in the first step.
Then start to think about the algorithm you want to implement - and explain that algorithm to us so we can provide suggestions!
Right now I see:
  • You read an array from your file and pick the first element of that array.
  • Then you build an array from that single element, just to pick the first element again… (???)
  • Using that element to run a FOR loop x times.
  • Executing the same code in the loop x times, but only using the result of the last iteration. What's the point here?
  • That last scalar result is again build into an array (of just one element), then that array is sorted: what's the point in this operation???
  • Then the sorted array of float values is shown in an integer indicator: are you sure you display the expected values?
  • Why do you need a formula node for this small math formula? Why not use plain G functions?
Please explain the term "wavenumber"!
How do you want to convert wavelength to "wavenumber"? Which algorithm is used for that conversion?
Message 2 of 22
(2,578 Views)
Thank you for your reply,
I created a below VI, which is now doing the following,
1. load the data from txt file (wavelength vs intensity data) and plot it in graph
2. converting the x-axis to wavenumber using Raman shift equation in formula loop
3. plotting wave number vs intensity in a graph and saving the data to a txt file. I feel this is working according to my plan. Bu I have a question  - I used for loop for formula loop but i did not use any iteration and give any command to n, but it still working.
So now I need to take the FFT of a wavenumber data which i got now and multiply it with Hann window and take IFFT - to get a clean spectrum.
Any suggestions will be highly appreciated. Attached the images for the above code.
Message 3 of 22
(2,563 Views)
Hi KK,
As you only attach images of code I will do the same:
No FOR loop needed!
Do yourself (and us) a favor and post real code next time! We cannot edit/debug/run images with LabVIEW…
Message 4 of 22
(2,540 Views)
Thank you for you help, I have implemented your suggestion. Now I am using this generated wave number vs intensity spectra to do the following steps,
wave number vs intensity spectrum
  I
FFT
  I
multiply with Hann window
  I
IFFT
  I
final spectrum in waveform graph
Below I attached the VI, I could not see any output spectra after IFFT. maybe I made some mistake in the code, if possible could you help me with this.; I have attacked data file (wavelength vs Intensity) also.
Thank you
KK
Message 5 of 22
(2,515 Views)
Hi KK,
please downconvert your VI to LV2021 or (even better) LV2019. (File->Save for previous)
Many long-time users of LabVIEW didn't upgrade to LV2022/LV2023 yet due to subscription license issues…
(Did you notice my signature line?)
Message 6 of 22
(2,510 Views)
Hi GerdW,
Please see the attached down converted VI. please let me know if this is working or any modifications are needed.
Thank you
KK
Message 7 of 22
(2,506 Views)
Hi KK,
Now I'm missing your datafile…
Why do you need that sequence structure?
Why do you use those PtByPt-FFT functions? Do you know what PtByPt-functions are good for?
Message 8 of 22
(2,494 Views)
Hi GerdW,
Please find the attached data file.first column is wavelength and second column is intensity.
sorry about that, I am new to Labview, so using google and following previous Labview projects I made this code. Your suggestions are really help full.
Thank you
KK
Message 9 of 22
(2,490 Views)
Hi KK,
see this:
Message 10 of 22
(2,471 Views)
