spread sheet file to the formula loop
Accepted by topic author KK54321
Hi GerdW,
Thank you for your help,
I have exactly created VI as you mentioned above. But I am unable to get the plots for FFT, IFFT, FFT2. Instead I am getting an 1D array. I have attached the VI for your view. Could you please help me with this. Also, I need multiply with hann window function to the first FFT then need to take IFFT.
Thank you
KK
Message 11 of 22
(1,017 Views)
Thank you. I figured it out.
Message 12 of 22
(1,009 Views)
Hi GerdW,
I have incorporated all your suggestions, Now I am moving to the actual program as follows, (goal is to educe the spectral noise to get a clear spectrum)
1. Load and convert spectrum from wavelength to wave number
2. take FFT
3. Multiply with Hann window
4. IFFT.
Some how I made the above steps, and my final spectrum looks good. But I am facing a problem where the spectrum peaks are repeating if you see the plots its like mirror image. How to avoid this. Could you please help me with this. I have attached the VI for your view.
Thank you
KK
Message 13 of 22
(984 Views)
Hi KK,
do you remember my older message?
Message 14 of 22
(977 Views)
Sorry I forgot to down convert. Please find the attached VI.
Thank you
KK
Message 15 of 22
(972 Views)
Hi KK,
No, you have not…
@KK54321 wrote:
2. take FFT
2. Why is there still a PtByPt function used? I already told and showed you to use the "regular" functions!
3. I don't see tis in your VI. And I already showed you how to apply a Hanning window…
Message 16 of 22
(969 Views)
Hi GerdW,
Thank you for your reply. Yes I have created a similar similar VI as you suggested. But I am only seeing noise in the final IFFT. I suppose to get clean spectrum without noise, that is the goal. Then I modified it to see some peaks in the final IFFT.So here I use PtByPt VI to get window function and multiplied it with FFT, then i took IFFT, finally i see some peaks. The Vi you suggested, there I need to multiply with Hann widow and FFT then use IFFT. I could not find any option to choose window size. is it possible with the labview.
Thank you
KK
Message 17 of 22
(960 Views)
Hi KK,
There is a misconception: you don't get a spectrum from an InverseFFT!
The IFFT converts data from frequency space to time space…
Message 18 of 22
(953 Views)
Hi GerdW,
Thank you for your reply. IFFT converts freq - time space that's true. But the actual FFT will be done on the 1D array, that will be y-axis (intensity in our case). I have attached an image from a research article, where they have done the same process. So here I am trying to do the same process. Please let me know if you have any suggestions for me.
Thank you
KK
Message 19 of 22
(938 Views)
I have a spectrum with background and some noise. I need to get rid of these effects and make a clean spectrum. I have made a labview code for this purpose. Here are the steps for the code,
1. Program loads the data file and converts it to wave numbers
2. Taking the FFT of wave numbers spectrum
3. Multiply with gaussian window
5. Then IFFT,
My final spectrum looks good, and i am able to reduce the noise, but still background is present in the final spectrum. But here the problem is if I given a clean spectrum it produces some extra noise to it, also adding extra peaks to the final spectrum. Can someone help me with this. I have attached the VI and data file. We can also multiply with a high pass filter with FFT and then do IFFT to reduce the noise, but i am not sure how to do this in labview, I have attached an image for this process from an research article.
Thank you
KK
Message 20 of 22
(954 Views)
