spreadsheet string to array notation
Hi all,
I am using the spreadsheet string to array function and basically my problem is as follows:
My inputs are in scientific notation so I use this in string format. The data is separated with a ",". What I get is just the argument rounded.
As I just realized I didn´t make myself clear I´ve attached a photo of the problem. Notice that probe 4 is the input from which I want to build the array, and probe 5 is the output. I just have the 9 but what happens with the rest of the number?
PD: I´ve tried many formats but none of them seems to work.
Thank for your help
(3,796 Views)
Accepted by topic author rodriferfe
Your system is set up to use a comma (,) as the decimal point?  Try using "%.;%^.3e" for your format.  The "%.;" tells the scan to use the period as the decimal point.
(3,788 Views)
That´s brilliant, it works perfectly, thank you very much for your help!!!!
(3,780 Views)
