spreadsheet with header
Hello! I'm trying to save some data file but I can't get the header on top of the data.
Thanks in advance...
______________
KowdTek
LabVIEW 2009
One Step At A Time, Maybe Two...
(2,504 Views)
Accepted by KowdTek
You did not add the header to the array.  Also, when you build the 2d array, your data will be arranged in rows, so you need to transpose your data. Please see below. You will need to wire "Data" into the write to file vi.
(2,499 Views)
