square brackets
If my VI used to be called xxx.vi and now whenever I open it, it opens as following [xxx.vi] and I get (I think) coded VI. How do I go back to original and open it without brackets?
Message 1 of 14
(6,295 Views)
right click on the the FP icon of the opened VI, select properties --> windows appearance.
It seems that the VI has a blank name in the title bar.  It is still xxx.vi on disk, but the title bar would be blank when it executes.
Paul
Message 2 of 14
(6,285 Views)
That did not help.
Message 3 of 14
(6,265 Views)
did you check the box the says "same as VI Name" and click OK?
can you post the VI in question?
Paul
Message 4 of 14
(6,262 Views)
Okay, now I lost the brackets [xxx.vi], which is good. But I still get the coded VI, instead of icons. If you dont know what I am talking about I would send it to you.
Message 5 of 14
(6,257 Views)
Sorry, I do not know what you mean by the 'coded vi'.  If you could post a screen shot it would be most helpful.
Paul
Message 6 of 14
(6,254 Views)
Do you mean you are getting the block diagram showing up on execution instead of the front panel? Is that what you meant by the coded vi?
Jeff
Using Labview 7 Express
Message 7 of 14
(6,251 Views)
I attached the VI. The problem is in block diagram...
Message 8 of 14
(6,243 Views)
Is this NOT what you are seeing?
Message Edited by Stradis on 10-01-2007 03:15 PM
Paul
Message 9 of 14
(6,238 Views)
It is what I am seeing, but what I would like to see is something like this...  (attached)
Message 10 of 14
(6,232 Views)
