square spiral
as title, can somebody tell me how to create a square spiral graph out of Labview, please?
thx.
square spiral: http://quiltingstencils.com/productimages/bs185.jpg
(3,977 Views)
All you need to do is work out the coordinates of each corner and feed them into a graph - if it is a line graph the points will get joined together.
There will be fairly simple alogrithms where you add or subtract ever decreasing amounts to the x and y coordinates.
Give it a go and post your attempts if you get stuck (it should be easier than last time)
(3,959 Views)
Accepted by jhr342002
I think this does what you want
Randall Pursley
(3,924 Views)
thank you so much!!
(3,829 Views)
thank you, Ian. I'm still pretty new to LV and have a lot to learn.
(3,828 Views)
