stacked sequences
@P Anand wrote:
I won`t say that it has to be removed because still it has some use like forcing the code to execute a part of the code which does not have error wire.
You don't need a stacked sequence structure to accomplish this. However, like the post by for(imastuck) indicates you can't simply get rid of it because it would break too much legacy code.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 11 of 25
(1,879 Views)
NO!Smiley Wink
Don't get rid of the Stacked Sequence!
I will use a Stacked Sequence in my very often.
Frame 1 - contains all of the code.
Frame 2 - Contains an image of the State Diagram that documents the code flow. All I have to do is flip to frame 2 to see the design.
Of course if NI would restore the State Diagram Editor to its former glory I would not need the stack sequence.
Ben
Message 12 of 25
(1,868 Views)
Ben, I'm glad you never miss a chance for that plug.
Message 13 of 25
(1,854 Views)
@Ben wrote:
NO!Smiley Wink
Ben
PLUG #2!!!
Edit: I should really read all the responses first, I'll see crossrulz beat me to it. I'll add a link to another one for good measure
Message 14 of 25
(1,832 Views)
If it gets Jeff K on our side, I plug all day.
Smiley Happy
Ben
Message 15 of 25
(1,798 Views)
There is absolutely nothing wrong with the Stacked Sequence Structure. All problems stem from the abomination known as the sequence local.
Message 16 of 25
(1,789 Views)
Although I do not agree with your assertion about its need (you can force program flow using other methods, i.e. Flat Sequence), I do see the problems you would have with legacy code.  That's something I had not considered.
I am not familiar with FPGA; therefore, I do not see the reasoning behind using a stack sequence with it.  Perhaps someone can expand on this thought on why a Stacked Sequence would work better than a State machine if using FPGA.
Reese, (former CLAD, future CLD)
Some people call me the Space Cowboy!
Some call me the gangster of love.
Some people call me MoReese!
...I'm right here baby, right here, right here, right here at home
Message 17 of 25
(1,744 Views)
Whether its a Flat sequence or a stacked sequence I would use only single frame to force the data flow :D. I forgot to state the use of this in larger code. We use to initialize the code in one frame then run the code in another frame then re-init the code in the final frame. I am not sure about the legacy code.
Message 18 of 25
(1,733 Views)
Yes, but you can do the same thing with a State machine.  What I am talking about are uses for a Stacked Sequence where a State machine just won't do.
Message 19 of 25
(1,722 Views)
Yes if my design has Init >> Execute code >> Re-init and exit do you think it is necessary to use state machine?. Because this sequence of execution is never going to change and I feel it is unnecessary to bring a state machine into play.
Message 20 of 25
(1,713 Views)
