‎12-07-2007 07:53 AM
‎12-07-2007 08:12 AM
hi Claudia,
I can't say to you what you should exactly because my current labview version it's 8.5. But I use many times RS232 and it's necessary to install visa runtime. You can download it in NI website
‎12-07-2007 08:18 AM
‎12-07-2007 08:31 AM
‎12-07-2007 10:07 AM
Hi guys,
The first two answers tell me to install the run time VISA machine and the last one said that what I did is OK. I´ll try to install, because I don´t know what to do. I´ve tested the communication using the Hyperterminal and it is working well. So it exclude hardware problems.
Thank you.
‎12-07-2007 10:16 AM
‎12-07-2007 10:32 AM
I ´ve just saw at http://digital.ni.com/public.nsf/allkb/D26B50B17AA9C3FD86256F1F00661A49 that I don´t have to install the VISA Run-time engine. So, does someone has any ideas?
‎12-07-2007 12:58 PM
Hi Celia,
You might check to make sure that the VISA Resource Name you are providing in your application is the same as the name the new machine is using. If you build the application and it is looking for a specific resource that does not exist on the new machine, you might see an error similar to this one.
‎12-07-2007 04:24 PM
I don't see that statement in that link at all. It says if you don't have VISA runtime engine installed on the other machine, you will have to include it in your application's installer. All of this was in paragraph #1.
‎12-10-2007 07:28 AM
Hi Ravens Fan,
I´ve already installed the run-time VISA engine, but my serial communication isn´t still working.
Thank you
