standard deviation for the slope from Linear Fit
hi
this should be indicated in the help file of Labview !
regards
Message 11 of 12
(631 Views)
Since I see that many of you are physicists, I ask you if you ever tried to implement ntuples and, in the affirmative case, if you can make the code available maybe in the Examples Section.
Thank you
Message 12 of 12
(611 Views)
