state array
I am trying to make a state array. I have attached  such an array that I found somewhere. It is orange-red colour. My attempt is in black and I cannot add elements. Anyone can help. The arrays are in the attached file.
(3,637 Views)
Hello labview1958,
you have to set the type of your array.
So just put a text constant into your array and it will change color. After that you can easily add/change elements.
(3,636 Views)
"So just put a text constant into your array and it will change color"
How to do that? I tried something like trying to type text but did not work.
(3,627 Views)
Hello labview1958,
take a string constant from the strings palette und put that into your array constant. It's like all the other types of constants: take it from the palette and put it on the block diagram...
Or: RTFM!
(3,622 Views)
