‎10-17-2016 09:14 AM
Im trying to email the labview state diagram from the toolkit after it generates the xml documentation using the "generate documentation". How do I quickly bundle and email this to a coworker?
‎10-18-2016 10:14 AM
Hey id,
Just to clarify, what exactly are you wanting to bundle and email? Is it your LabVIEW code or the .xml document?
‎10-18-2016 02:55 PM
the XML document with the diagrams and pictures
‎10-19-2016 08:30 AM
Hey id,
Are you trying to email the document within your code? If so, can you send a screenshot or snippet of that code, so I can see what's going on? If not, are you getting errors or just having trouble sending it as a regular email attachment?
‎10-19-2016 08:45 AM
I am simply trying to email the document to another cowowrker so he can review the diagram. What he gets is an XML document without the pictures
‎10-20-2016 10:33 AM
Will you send a screenshot of what you see on your XML document, so I can see what part is not getting sent? When I use the Generate Documentation, I get an XML document containing just text and a separate folder in the same location containing the image files, as shown in the screenshot below. If that is what you are also getting, you could create a folder with all of those files in it to email.
‎10-20-2016 10:44 AM
Yes, my problem is my state diagra has 65 picture files and a few others with it.
‎10-21-2016 10:21 AM
So, is the file size just too large to email? Have you tried placing it all into a folder and creating a .zip file from it? If this still is too large, this would be a limitation of your email and not a LabVIEW issue. You may just need to find an alternate way of sending or emailing him the files, such as through an online cloud storage like Google Drive or Dropbox.
