state machine - wait in user input before going to next state
I think everyone will get the idea. But you could change which solution is more appropriate. I think it is under options next to the post.
Click "Not the solution" under options then select the correct one.
LabVIEW 2012
Message 11 of 15
(1,120 Views)
Anyone any idea why one of my states wont execute.
This sequence is:
Initialise System
Charge system
Then try and go to “agitate sample”
For some reason it just replays its current state, however, im sure i have it set up so it should be going to the “agitate state”
I don’t yet have the abort configured, so don’t pay any attention to that.
Many thanks
Message 12 of 15
(1,102 Views)
The Agitate Sample local is hooked to the third input in the Build Array in the Charging Complete state.  when converted to numeric that bit has a value of 4.  If only one button (or none) is pressed at a time, the possible inputs to the case selector are 0, 1, 2, 4.
It is better to connect signals by wire rather than using local variables.  Learn about Event Structures for handling the buttons and perhaps a Producer/Consumer architecture.
Lynn
Message 13 of 15
(1,092 Views)
Ah thanks for that, so for argument sake, i pressume if i had another button in the structure, it would need to address frame 8 of the structure?
Thanks again.;
Message 14 of 15
(1,089 Views)
Yes.  The booleans act as binary bits so the counting is in binary.
Put a probe on the wire to the selector and watch the values change as you push buttons.
Lynn
Message 15 of 15
(1,085 Views)
