state machine with analog output
I have a vi designed to output an analog signal to an acuator and now I just want to add in some timing elements. My intention with the attached vi was to provide signal 1 for a certain amount of time, then switch to signal 2. I'll add a little wait time in between the two eventually.
What is going wrong here? I haven't changed the DAQ assistant or any hardware. I looked up this while loop, shift register, case structure combo on another thread. The signal graph displays the signal correctly, but no signal is coming out of the DAQ. I'm sure its something simple, I'm not the best at using labview elegantly.
Message 1 of 8
(3,892 Views)
What is your DAQ hardware? Is it capable of hardware timed AO? Did anything ever work? What error messages do you get?
We need more information to help you.
Lynn
Message 2 of 8
(3,879 Views)
That is an odd way to do the state machine, but I see no issues with that part of it.
Is your hardware returning any error, or is it acting like it ran?
Message 3 of 8
(3,875 Views)
NI USB-6212.
The vi worked when I was manually switching the signals with a toggle seen in the attached vi. I took that vi and worked on adding in the timing.
I get no error messages.
Message 4 of 8
(3,864 Views)
The false case never executes because your stop condition is when i = 2.  That happens before your timer elapses.
aputman
Message 5 of 8
(3,840 Views)
The loop only repeats once the timer elapses so i = 2 works fine. Plus, the signal graph shows both signals one after the other. If I remove the condition and run it continuous it will repeat the alternating pattern.
Its okay with displaying the correctly timed signals on the graph, its just not getting to the analog output. I suspect the DAQassistant is not in the right structure, I don't know where it belongs. I double checked the device and channel its suppose to be outputting to. The same device name and channel works in the alternate VI I posted. There is some syntax (if thats the right word) problem going on.
Message 6 of 8
(3,814 Views)
Accepted by standardms
I'm not even sure you need any of the timing VIs in there.  You are generating 1 second worth of data and then telling the DAQ to output that data.  That takes a second to do.  Therefore, the DAQ Assistant is taking up your second of time.  Therefore, you just need to toggle your boolean.
Message 7 of 8
(3,797 Views)
This worked. Simple and made sense.
Now I just need to tweak it to control the duration/wait
Thanks!
Message 8 of 8
(3,739 Views)
