stepping
How can I implement next case:
need number output, next after one finished, so loop will look:
number 5 for 5second
number 8 for 6 seconds
number 9 for 4 seconds
I try with case and sequence but it was not working OK, any advice?
_________________________
Rookie; LV 2011 on WIN 7
Message 1 of 44
(5,581 Views)
Can you post what you've done so far?
Message 2 of 44
(5,578 Views)
Well started with this, but not working; here I try to implement
 13.5 for 5s then after this
 17    for 6s then after this
 13.5  for 5s
But here I got at final all three numbers together, I need for every step just "one number", which I write ..
Message 3 of 44
(5,572 Views)
Can you explain a bit more on what exactly you want to achieve then its easy to get the solution.
Message 4 of 44
(5,566 Views)
As I write, I need this:
number 13.5  for 5s then after this
number 17    for 6s then after this
number 13.5  for 5s
then again from beggining number13.5 for 5s.....
Message 5 of 44
(5,564 Views)
I'm sorry, but I don't understand what you are asking for at all. What do you mean by "need number output"? Output to what? A dialog box? An indicator?
Try posting in your native language, then perhaps someone can do the translation for you.
Message 6 of 44
(5,557 Views)
I need output number as string...
Message 7 of 44
(5,555 Views)
Like this?
There are better ways... this is to clairify what you want.
Message 8 of 44
(5,550 Views)
That tells me absolutely nothing.
Message 9 of 44
(5,548 Views)
I can't open this, have 8.5 version;
Message 10 of 44
(5,543 Views)
