stepping
I don't understand what you mean with:
"Then use a producer/consumer design as shown in the examples."
_________________________
Rookie; LV 2011 on WIN 7
Message 31 of 44
(2,409 Views)
Sorry to butt in, but perhaps a guessed rephasing of the OP's requirements, as we STILL are unsure as to what is actually wanted.
Send the string "13.5" to a serial output using VISA
Wait 5 seconds
Send the string "17" to a serial output using VISA
Wait 6 seconds
Wait 5 seconds
Is this correct?
What do you want it to do next?
You say that this output is to be sent to a programmable power supply. Does the power supply need JUST the number? Or does it need a "set volts" command. Do you finish after sending the number or do you need to add a terminator or carriage return to let the power supply know that you want 13.5 volts, not 13.56 (and it's waiting for the 6)?
Rod.
Message 32 of 44
(2,408 Views)
Wait 5 seconds
Wait 6 seconds
Wait 5 seconds
Is this correct?
That's precisely what's shown in the VI posted in reply 23, and apparently that's not what he wants.
At this point, unless the OP CLEARLY explains what he wants, this guessing game will continue for another 3 pages, and frankly, I have better things to do.
Message 33 of 44
(2,398 Views)
Well I have everything worked fine, all commands all read/write VISA...THERE IS NO PROBLEM WITH THIS !!!
But as I said 10x times before, example from Dennis_Knutson(at end of page 2) is exactly what I need, just value(in his example visa) must be outside of for loop. I need this because of other things in my whole schematic..
Message 34 of 44
(2,397 Views)
You don't have a schematic.
I told you how to pass a value from one loop to another.
Unless you post your actual VI, I can't help.
Message 35 of 44
(2,382 Views)
Well I don't know what you mean with "producer/consumer design" ?? I just simply need value outside for loop, this is everthing what I need.
Message 36 of 44
(2,378 Views)
You can't have the VISA send outside the loop if you want the time delays to work.  The loop is what creates the timing.
In Dennis' example the actual "values" are already outside the loop.  They are in the string array that goes INTO the loop.
If you really need more help on this project please explain your ENTIRE APPLICATION properly.  Use your native language if you can't translate it to english.
Sorry to say this but many of your posts seem to be asking for VERY simple things that you should already know if you just studied some LabVIEW.  Take some tutorials!Smiley Frustrated
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 37 of 44
(2,370 Views)
Have you ever tried Help>LabVIEW Help?
While you are at it, look up notifiers. That is another way you could have your VISA Write in another loop. Note that your posted example with the indicator outside the for loop I posted is clearly not possible.
Message 38 of 44
(2,366 Views)
In Dennis' example the actual "values" are already outside the loop.  They are in the string array that goes INTO the loop."
I know that, so for these reason I ask question, how can make what I want and all of you suggest me "for loop". Now is problem because I need this changing value outside of loop.
I hope that with this picture will be all CLEARED what I wnat to do:
"Number to fractional string" must be here because of first and second case....
Message 39 of 44
(2,364 Views)
As I already said, you can't. Your request is silly.
Message 40 of 44
(2,360 Views)
