sticking the controls while resizing front panel window
I have been using three controls on the rightmost part of the front panel. On resizing the window , I want the controls to be sticking to the right of the front panel only. I have attached an image for your reference. In that image i want the three buttons to stay on the rightside of the panel even after maximizing the front panel. Can anyone provide me a solution for this?
Aishwarya
(4,065 Views)
You'll need to use a vertical splitter to break up the front panel. The buttons would be placed on the right hand side of the splitter, and then set the splitter property to lock it to the right-hand side of the window when it is resized. You can play with the splitter's appearance (colour, size, etc) to make it appear invisible, so it's not obvious a splitter is even being used. This is a handy technique for tool bars and status bars too.
Certified LabVIEW Architect
Unless otherwise stated, all code snippets and examples provided
by me are "as is", and are free to use and modify without attribution.
(4,051 Views)
I always solve this problem with property node and using position of control
did you test that ?
(4,035 Views)
Thank you so much. Your suggesstion solution is working. 🙂
(4,018 Views)
