‎05-27-2016 07:39 AM
Hi all,
in my application there is a graph with a multiplot cursor with its legend.
User moves the cursor and plot values are shown in the legend but I want to avoid user to delete the existing cursor or to create a new one by using the cursor legend.
It is possible to disable the run-time menu of the cursor legend? I've tried but without success. It seems that the only way is to create a custom cursor legend with plot values.
Do you have any idea?
Thanks all
Solved! Go to Solution.
‎05-27-2016 07:50 AM
In front panel, click on view then uncheck cursor legend
‎05-27-2016 08:02 AM
also each time it is passing last values in next iteration. When it will run for hrs then it will hang
‎05-27-2016 08:03 AM
Please ignore last comment
‎05-27-2016 08:50 AM - edited ‎05-27-2016 08:50 AM
@Ranjeet_Singh wrote:In front panel, click on view then uncheck cursor legend
If I uncheck Cursor legend, it will be not visible. I don't want to make it invisible; I'd like the run-time menu of the cursor legend to be disabled
‎05-27-2016 09:10 AM
A hack way of doing it would be to put a decoration rectangle over that part of the graph and color it transparent.
‎05-27-2016 09:11 AM
‎05-27-2016 09:12 AM
@RavensFan wrote:A hack way of doing it would be to put a decoration rectangle over that part of the graph and color it transparent.
Good!!! I didn't think about it.
First rule: think out of the box
