How to disable cursor legend of a graph?
Hi all,
in my application there is a graph with a multiplot cursor with its legend.
User moves the cursor and plot values are shown in the legend but I want to avoid user to delete the existing cursor or to create a new one by using the cursor legend.
It is possible to disable the run-time menu of the cursor legend? I've tried but without success. It seems that the only way is to create a custom cursor legend with plot values.
Do you have any idea?
Thanks all
Message 1 of 8
(5,429 Views)
In front panel, click on view then uncheck cursor legend
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 2 of 8
(5,425 Views)
also each time it is passing last values in next iteration. When it will run for  hrs then it will hang
--Ranjeet
Message 3 of 8
(5,419 Views)
Please ignore last comment
--Ranjeet
Message 4 of 8
(5,416 Views)
If I uncheck Cursor legend, it will be not visible. I don't want to make it invisible; I'd like the run-time menu of the cursor legend to be disabled
Message 5 of 8
(5,406 Views)
Accepted by topic author sqrt(-1)
A hack way of doing it would be to put a decoration rectangle over that part of the graph and color it transparent.
Message 6 of 8
(5,400 Views)
i do not think you can do it with real legend you can hide Cursor legend then you have to design a indicator look like cursor
use property node and read cursor position for this indicator in this case you can have legend but you are able to disabled it
Message 7 of 8
(5,396 Views)
Good!!! I didn't think about it.
First rule: think out of the box
Message 8 of 8
(5,395 Views)
