stop while loop after last element of array
I want to stop a while loop after the last element of an array. I cant use the array size way because the size of the array can change within the program.  What should I do?
(8,252 Views)
Use a For Loop with autoindexing?
Does it have to be a While Loop?
(8,249 Views)
Taki1999 mentioned 'For Loop' already. You can activate also the 'Conditional Terminal' of the For Loop, if you need to stop the loop because of any additional condition, like Boolean value, etc...
(8,233 Views)
And of course you can use array size to stop the loop. The for loop is the smart thing to use but a simple comparison between the array size and the iteration count can be used.
(8,215 Views)
Accepted by fghfghgfhfhg
Why don't you use the empty array function like this...?
2015-07-30 18_02_48-G15-0440.vi Block Diagram on ABT.lvproj_My Computer rev. 36 _.png
(8,126 Views)
I'm not sure the OP meant to stop the loop when the array is empty.  I think they want to stop it after the least element was processed.  At any rate, generally use a for loop if you know the size of the array ahead of time, a while loop if you do not.
Bill
CLD
(Mid-Level minion.)
(8,114 Views)
Ok Thanks guys
(8,040 Views)
