stopping a running exe
hi need help.
i have a vi with two button
1. button enable - run the exe automatically
2. button disable-stop/terminate the running exe
i can do the first button(run the exe) but i cant do the second button
(4,943 Views)
i have a vi with two button  <=====  Is this the VI that is the executable?
1. button enable - run the exe automatically  <=====  Is the executable a LabView VI?
i can do the first button(run the exe) but i cant do the second button  <===  ????
I ask because the last sentence makes it sound as if you have a VI that has two button and it is not an executable.  It calls an executable...
Is that so?
Before suggesting anything, I would need to know what type of executable we are talking about...
Can you provide more description?
RayR
(4,939 Views)
hi joe i attach the vi i have done wit this. im not sure this is a correct way to do this but i tried.
the exe tht should run is actually done  in visualbasic6.
wen the user click on the enable button the .exe will run automatically.
wen user click disable button the running exe should terminate from running.
thk u..
Message Edited by jeyanthi on 06-17-2008 08:43 PM
(4,936 Views)
Hi Jeyanthi,
Keep the Enable button inside its event case.
Also, change both the button events from Mouse Down to Value Change.
See the modified attachment.
- Partha ( CLD until Oct 2027 🙂 )
(4,913 Views)
Hi Jeyanthi,
The System Exec VI will run your executable in a separate process from LabVIEW.  LabVIEW by itself cannot kill the process, however, you can use a second System Exec to call a Windows command which will.  See the following link:
http://digital.ni.com/public.nsf/allkb/80432B061C5A4C888625705400737BE8?OpenDocument
Jeremy_B
Applications Engineer
(4,885 Views)
Thanks Jeremy,
THis will be quite useful.  Unless there are hooks in the software of Active-X class available for external control, it is difficult to kill a rogue executable..
(4,879 Views)
