stopping a tank from transferring a liquid to another one
i have two tanks to be filled one by the other i filled the first one within 10 seconds but i need to stop the transferring to the another for five seconds and i don't know how to use the timer for that.
after that i need also to repeat the whole operation again to the infinity....hope you guys help me pleaase
(2,928 Views)
hey guys i'm a noob in labview and i need your help in solving this problem.
the question is:suppose we have  two fluid tanks in a chemical factory. After the first tank is filled with liquid in 10 seconds, the mixer runs for 5 seconds. Afterwards, the liquid in the first tank is transferred to the second tank in 10 seconds and the heater works for 5 seconds and the liquid in the tank rises to 100 degrees. Then the liquid in the second tank is drained in 10 seconds and the whole process starts all over again. Design a labview program that allows you to follow the process. The LEDs should light while the mixer and heater are running. After the second tank is empty, the temperature in the thermometer should drop to zero. The front panel should look like the picture below.tanks.JPG
(3,036 Views)
Some of your classmates already posted very similar problems and pictures over the last few weeks. For example here..
(It also really helps if you give a reasonable subject when posting. "labv" is not a reasonable subject!
We don't do homework but we would be willing to help if you try to first solve it yourself, shows us what you made so far, explain why you think you are stuck, and then ask specific questions.
(3,024 Views)
ok i will try but i need some instructions and tips cause i've just started using labview and i don't have enough experiement to start that by my own..i will be pleased if you help me.
(2,946 Views)
Are you learning on your own?
In that case start with the learning resources on top of the forum.
If this is for a class, go through your course material. It is unlikely that your teacher demands any skills that have not yet been covered.
See how far you get.
(2,925 Views)
this semester was terrible because of the viruse and the education is so bad we are suffering with doing the home work the teacher send the question as it is above....
(2,920 Views)
