strange paths when using Get VI Dependencies
This is more curiosity than a request for help.
I have implemented lists of user generated dependent Vi's and Ctl's as part of my system startup as a reference and I came up with a strange anomaly.
One Vi has two more instances in the dependency list
C:\Users\me\SYSTEM\Find_a_TP.vi
C:\Users\me\SYSTEM\Find_a_TP.vi\9eaf5943-a248-4e95-b650-d3c6088aceb2.vi
C:\Users\me\SYSTEM\Find_a_TP.vi\cac5c9ea-292d-43f3-909b-b2ec2b433a2c.vi
I removed the vi from the system and all 3 entries were removed, putting it back and all three were returned with the same extras.
It is not re-entrant and has a single call.
Does anyone know what these are please
Jessica
(1,471 Views)
The numbers at the end indicate cloned instances. Your VI is set to be reentrant (either using a clone pool or explicit clones)
Rolf Kalbermatter  My Blog
(1,444 Views)
That's news to me.  Awesome.
Bill
CLD
(Mid-Level minion.)
(1,431 Views)
This is what I thought it was, but the vi is not set as re-entrant and I have never set it as a clone as I would not know how.
As it is not set as re-entrant how else can it become a clone.
(1,430 Views)
Accepted by topic author jessica_kh
Those are likely calls to .VIM files in that VI.  If you look you will probably find 2 of them in use, which could be 2 of the same one or 1 each of two different ones.
VIMs look like that because each time you put it on a block diagram, it creates a tiny copy of itself that embeds itself onto the block diagram, which is why it looks like a VI has another VI it it.
If you set the "Keep express/malleable?" setting to False, it should go away and you will instead see the VIM in the list.
(1,405 Views)
I was not aware of VIM files and it seems that \i used one without knowing. That VI has a "Is Value Changed" function that now I  see is a VIM.
Thank you. It was annoying not knowing what was happening.
Jessica
(1,319 Views)
