stream ni spy stream to labview program
Is there a way to stream the NI spy messages to a labview program instead of a file. Perhaps via an API or is there a method of duplicating the features through the Labview Program?
(2,414 Views)
Hello Steve Block,
What version of LabVIEW are you using? Recently NI Spy has changed its name to NI I/O Trace.
There should be a NI I/O Trace Toolkit under the functions pallet in LabVIEW, within the Measurement I/O pallet.
Also see:
https://www.ni.com/docs/en-US/bundle/ni-io-trace/page/iotrace/bp_help_file_title.html
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019ZhgSAE&l=en-US
https://forums.ni.com/t5/Additional-NI-Software-Idea/Creation-of-I-O-Trace-API/idi-p/1865371
Matthew R.
Field Applications & Systems Engineer
(2,372 Views)
