System Numeric indicator bug?
Has anyone noticed that when you replace an indicator from modern to system, the size properties is not retained and that it will use the default size of the system numeric. This seems to happen only on indicators and not on controls.
I do not know if this a bug on LabVIEW 2012 SP1 and if it is, does anybody know where I can get the fix fot it?
(2,676 Views)
Hey macolit,
The behavior you are describing is actually intended. Performing a replace operation in LabVIEW basically just automates the manual operation of delete node, drop new node, rewire. All settings associated with the new node will be the default settings.
I hope this helps explains what you were experiencing!
Robert R. | Applications Engineer | National Instruments
(2,625 Views)
