string convert to array
Well, you are changing specifications on us.
Before it was:
point 1; voltage 2; current 0.5;
point 2; voltage 3; current 0.7;
Now its:
"chan 1;inp on;curr 1;chan 2;inp on;curr 0;chan 3;inp on;curr 2;...."
Do you need the "inp on" part? If so, as what?
Message 11 of 14
(1,472 Views)
Your file also seems corrupted. Sometimes there is no ";" delimiter.
for example
"...curr 0.5chan 8...".
Shouldn't that be
"...curr 0.5;chan 8..."
for consistency. Where does the file come from?
Message 12 of 14
(1,465 Views)
You are right, ther's always a delimiter ; and I need the Inp On to set on my channel.
This file is created by a compilation of other files that got only all the parameters (that represent one line of my test file)
for example my test.txt is made by : point 1. txt+ point2.txt+ point3.txt
and each point?.txt is like:
Chan 1;inp on;curr x;
Chan 2;inp on;curr y;
etc...
Message 13 of 14
(1,457 Views)
Accepted by akim_10
Maybe you can try something like the following?
If needed, you can parse out the numbers inside the FOR loop when you precess each row, for example.
Message Edited by altenbach on 03-05-2009 02:44 AM
Message 14 of 14
(1,453 Views)
