string to 2D string array conversion
I have a string like this below. I would like to extract all the texts within the quotes "  ". How to do that?.
05-Mar.20:52   skalyana    label type "BASELINE_1.2" (locked)
28-Apr.19:19   skalyana    label type "BASELINE_1.8"
i have tried using Match regular expression. I am able to extract one text within " ".
I would like to know how to extract all the text within " "
I have attached the vi for your reference
Kalyan
Message 1 of 23
(5,448 Views)
Use a While Loop with a Shift Register to keep looking until you've found them all.
Jim
Message 2 of 23
(5,430 Views)
    Thanks for the solution. One more clarification. I would like to remove the character " from the output.
Example like this
BASELINE_1.2
BASELINE_1.8
How to do that?
Kalyan
Message 3 of 23
(5,423 Views)
With a submatch, notice the parentheses and the new output (Match Pattern is expandable).
Jim
Message 4 of 23
(5,422 Views)
   I would like to extract the text between the character ( ) also.
 for example here locked (locked)
Kalyan
Message 5 of 23
(5,411 Views)
I don't see parentheses in your sample data.  Do you want what's in quotes AND parentheses or are you confused about the parentheses I've added?
Jim
Message 6 of 23
(5,406 Views)
I need both the text within " " and within ( ) from the above sample.
Kalyan
Message 7 of 23
(5,397 Views)
Sorry, I missed seeing (locked) in your original data.  This doesn't return them in order.  Is that important?
Jim
Message 8 of 23
(5,388 Views)
Hi Jim,
its simply superb...Smiley Happy
how to get more info on these 'Regular Expressions', is there any KB (knowledge base) or tutorial available for the same.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
Message 9 of 23
(5,383 Views)
Click on the "regex" link in my signature; it's my favorite.  Darin.K contributed this cool tool to the Community; it's worth downloading and playing with.
Jim
Message 10 of 23
(5,380 Views)
