string to array of strings to path
I want to read in a bunch of paths in the form of a long string such as:
C:\Files1;C:\Files2;C:\Files3....
such that when i enter it into labview it will seperate that string at the (;), store it in an array of strings, and then allow me to pass it into a while loop. Which vi can best accoplish this?
(4,889 Views)
I'd use the Match Pattern vi in the Strings Palette.  It allows you to search for a character and then gives you the string before and after the match.
I attatched a vi that you should be able to tweak to get it to do exactly what you want.
Enjoy!
~Rob Afton
(4,887 Views)
Accepted by Chris_H
Or just use the spreadsheet string to array function.
Putnam
Certified LabVIEW Developer
LabVIEW Champion
(4,879 Views)
LV_Pro
It will not let me create that string array constant. it only lets me use numeric types. how did you get that string constant?
(4,875 Views)
nevermind i got it
(4,873 Views)
Also make sure to change the delimiter to ";"
(4,866 Views)
