string to array
    hello all LabView Pundits
i have a string of binary numbers. (but the LV has considered them as deciamal, i think).
I want to convert them to a 1-D array such that each element of the array has each digit of the string.
in the sense:
String : 1010
i want the array to be a 1-D array such that each of the element in the array has one each of the above digits.
thankx in advance
more kudos to give 🙂
PS: will using "spreadsheet string to array" help???
Many more Kudos to give:)
(5,246 Views)
Accepted by topic author nikhilvastarey
Here's one possibility, assuming the string is clean and does not contain any unexpected characters.
Convert the String to a byte array and subtract 48.
Message Edited by altenbach on 01-01-2009 10:53 PM
(5,235 Views)
Hi!
I don't understand what is the meaning of substract 48. Could you explain, please??
Thanks.
(4,379 Views)
I hope this link is enough for you to answer your question.
Norbert
Norbert
Expert: Geometry
(4,376 Views)
Ok, but it's easier to say that 48 is the ASCII code of the 0 symbol, right?
Anyway tnks.
(4,371 Views)
Hi kantabra,
one should think you already got the point as you asked (basically) the same in that thread one hour earlier...
(4,366 Views)
