strings through frameworks
This code was complied as a Mac framework and used in the attached vi.
#include "untitled.h"
int test(buf)
char *buf;
buf = calloc(100,sizeof(char));
strcpy(buf, "etewrewr");
return 0;
Any ideas why I can't get the string out of the Call Library Function?
(3,337 Views)
Does a framework in Mac means the equivalent of a DLL in Windows?
Can I run this in Windows?
- Partha ( CLD until Oct 2027 🙂 )
(3,317 Views)
Yes, no.
And the answer is that if you define the string as char buf[500] instead of char *buf it works. have no idea why.
(3,309 Views)
Exo,
Could you attach the framework or DLL file that you created from this code so that I can use it in LabVIEW. Thanks!
Cheers,
Jonah
Jonah Paul
Marketing Manager, NI Software
(3,270 Views)
The framework didn't work because I configured it for a string variable when I should have configured it for an array of bytes. Just seeing char *buff can be misleading.
Thanks.
(3,262 Views)
