sub vi front panel opens when main vi opens
When I open my main vi I have one of my sub vi front panels that opens.  I looked in the properties for the sub vi and Show front panel when loaded is NOT checked. Is there something else I need to look at?
Message 1 of 15
(5,761 Views)
You might have a property node that is being call to open the front panel. Look to see if there is a reference to the sub VI somewhere in your code.
Tim
GHSP
Message 2 of 15
(5,757 Views)
Accepted by topic author Brent W
Check the (evil) SubVI Node Setup. This is not part of the actual VI, but is a right-click option setting off the icon of the sub-vi...
Richard
Message 3 of 15
(5,745 Views)
It is not check marked in the SubVI node setup either. I am new to LabVIEW and it is quite possible I checked something I shouldn't have, but I just haven't found it yet
Brent
Message 4 of 15
(5,719 Views)
please clarify;
Q1)
The sub-VI FP opens when
You open the top VI but BEFORE you run it
OR
The sub-VI FP opens after you start the top level VI
Q2)
If the above Q was after you run....
Is the sub-VI running or paused when it opens?
If it is puased you may have a breakpoint set in it.
Ben
Message 5 of 15
(5,713 Views)
A1) When I open the Top Level VI, the front panel of one of my SubVIs opens.  It is indepent of running the VI.
Message 6 of 15
(5,704 Views)
... read what Ben said, and as a double check, lets make sure in your first post you were talking about this....
Richard
Message 7 of 15
(5,700 Views)
Broken,
One notch down in your image is "Show ... When Loaded".
Ben
Message 8 of 15
(5,697 Views)
Ben wrote:
Broken,
Ben
Right, but having those things checked that I circled would case the VI to open also, so the O.P. needs to check that out. Also, by Friday, I'm tired enough that SnagIt the only program I can manage. Check out the cool wave effect.
Richard
Message 9 of 15
(5,692 Views)
Yes, but those would only cause the problem to occur when the program runs and gets to the subVI.  Since It is only when the VI is opened, not run, then those check boxes mean have no effect on the problem.
Message 10 of 15
(5,683 Views)
