sub vi front panel opens when main vi opens
Matthew Kelton wrote:
Yes, but those would only cause the problem to occur when the program runs and gets to the subVI.  Since It is only when the VI is opened, not run, then those check boxes mean have no effect on the problem.
Hey, I said I was tired. Smiley Tongue
Richard
Message 11 of 15
(1,502 Views)
Instead of all of this speculation, can you just attach the main and subVI?
Message 12 of 15
(1,490 Views)
shoot!!! - I goofed up.  I had the SubVI called twice in the code and I was only looking at the one instance.  I did have the box checked in the SubVI Node Setup.  Thanks to everyone that looked at this.
Brent
Message 13 of 15
(1,467 Views)
Broken Arrow wrote:
... read what Ben said, and as a double check, lets make sure in your first post you were talking about this....
<screenshot>
Hi Broken Arrow,
Which software do you use for screenshots?
Regards Nitin
Message 14 of 15
(1,454 Views)
Hi Broken Arrow,
Regards Nitin
As I said in my response to Ben, but it may not have been clear, the program is SnagIt.
Richard
Message 15 of 15
(1,442 Views)
