subarray memory coy problem
Hi, I read a PPT, NIDAYS 2004, I am confused with the following block diagram:
it said if the AAA wire is not connecte to the for loop node, then the time is very diferent with the time with AAA wire.  I tried, it is true. but I don't know the reason.
And I tried several times with different value constant linking to index port of subarray.vi , the times are different two. for example, 0 -- 115 ms,  1 --- 34 ms. 4 --- 295 ms.
(2,806 Views)
Accepted by concorpoly
solved, it is because labview memory management.
(2,767 Views)
Adding a little to the piece of info.
If you use
Tools >>> Profile >>> Show buffer allocations...
LV will put dots where the bufferes are created.
That option let you SEE the buffers rather than having to guess.
Have fun!
Ben
(2,758 Views)
