subpanel: position of displayed VI
Hi
Does anybody know how to set the position of the elements you display in a subpanel?
Volker
Message 1 of 16
(7,306 Views)
Open the vi which you are calling in the sub panel. Arrange the position of controls and indicators on the front panel.
Message 2 of 16
(7,301 Views)
That doesn't work.
I arranged the switch and the LED in the upper left corner of VI i'm calling, but in the subpanel it is displayed somewhere else.
Message 3 of 16
(7,296 Views)
Hai,
Could you post your code....
Ur previous post attachment is not visible and it is like above one.
Message 4 of 16
(7,288 Views)
I cannot see the picture that you have inserted. Can you attach the image? Also use Jpeg or png formats
Message 5 of 16
(7,282 Views)
Message Edited by BigBadWolf on 04-22-2008 07:37 AM
Message 6 of 16
(7,278 Views)
Try using the scroll bar of the vi to arrange the position.
Doesnt that help?
Also make sure that your visible front panel size of the vi is exactly same as the sub panel that you have placed
Message Edited by Vsh on 04-22-2008 07:45 AM
Message 7 of 16
(7,255 Views)
How do i make sure that the visible front panel size of the vi is exactly the same as the sub panel that i have placed
Message 8 of 16
(7,245 Views)
Right click on your subpanel and select create->property node->bounds->all
drop that on your block diagram and wire create an indicator.  that will give you the height and width of your subpanel after a quick run.
then, in your SubVI, go to file->VI Properties->Window Size and put the height and width in, then click and drag from the bottom corner of your subvi to make it as small as possible.  this "small as possible" size will be the same as your subpanel, and presto! everything fits.
Message 9 of 16
(7,238 Views)
And after you finish as what Jeff replied, arrange the controls and indicators accordingly.
Message 10 of 16
(7,235 Views)
