subpanel: position of displayed VI
Programmatically you should set the origin of the frontpanel of the subpanel VI.
Ton
My LabVIEW Ideas
Message 11 of 16
(2,647 Views)
I did exactly what jeff suggested, but the switch and the led both still appear far off the expected position.
How do i set the origin of the frontpanel?
Message Edited by BigBadWolf on 04-22-2008 08:27 AM
Message 12 of 16
(2,645 Views)
I'd recommend playing around with the origin stuff, because it can be a little tricky to figure out just by reading, but here's some places to start
Message Edited by JeffOverton on 04-22-2008 10:47 AM
Message 13 of 16
(2,618 Views)
After i restarted LabVIEW every suggestion started to work.
Message 14 of 16
(2,600 Views)
Useful addition to an old thread:  https://decibel.ni.com/content/docs/DOC-4136
Message 15 of 16
(2,175 Views)
Try Edit->Adjust Pane Origing, in your VI that you would like to show up in the subpanel.
As of LV19 you can select 'Scroll Panes to origin at run time' of the VI that you would like to show up in the subpanel.
This setting can be found in File->VI Properties->Window Run-Time Position
Message 16 of 16
(1,637 Views)
